Originally Posted by: grenstreet ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
OK I will be waiting
and thanks for the help
Grenstreet,
First off, you basically said everything is working correctly, cools, defrosts, etc.
I'm surprised, maybe I'm over thinking this ?
Let me explain how this evaporator fan circuit works.
L1(120 vac) comes into the refrigerator and feeds line voltage to the cold control and ADC board(K terminal/red wire).
L2(neutral) comes into the ADC board (L2 terminal/ white wire).
(with everything else working, I would have to believe the ADC board is OK)
At the cold control,
The red wire, supplies 120 vac to control, as long as the cold control circuit is closed, you have 120 vac out the control to the evaporator fan motor and the K terminal on the ADC board.
At the evaporator fan ,
You have 120 vac on the Yellow wire at the fan motor,as long as the cold control is closed and calling for cooling.
Your Neutral circuit is achieved through the Brown wire at the fan motor, through the defrost thermostat(as long as the thermostat is a closed circuit), and then through to the defrost heater circuit and out the heater through the White wire going into the cabinet.
I'm pretty sure you will find your problem there.
I think the White wire is chafed inside the cabinet wall or you have a loose connection there.
Were it me, I would do one of two things:
With a meter,set to read 120 VAC,
One meter probe attached to chassis ground(bare metal or green wire).
Check each terminal for 120 VAC (yellow at the fan, brown at the fan,brown at the thermostat, etc.) the whole circuit. when or where you loose the voltage or it drops. the wire or component before the loss/drop is the bad part.
*** These are "live" voltage tests with the unit running, BE CAREFUL ***
Another test would be to disconnect the white wire at the heater, attach a wire to the terminal on the heater, attach the other end of the wire to chassis ground, or a white wire to one of the other comonents, and see if the fan runs.(if it runs, the white wire is chafed in the cabinet, and can't carry the voltage.
Let us know how it goes, and what you find,
:cool: :cool: :cool:
