2 Pages<12
rizzo692
#11 Posted : Friday, December 3, 2010 10:38:49 AM(UTC)
rizzo692
hello again thanks for the freezer temp reply.ok so below zero is great! will give refrige a 24HR at Level 5 test...will advise thanks
rizzo692
#12 Posted : Saturday, December 4, 2010 6:52:53 AM(UTC)
rizzo692
level 5 reading was 40.5 and was curious so did do a test @ level 8 also that was for shorter period was @ between 34-36 hard to read temp. hope this helps? also i found by raising my temp to level 8 my beer tastes better and much colder!!
magician59
#13 Posted : Sunday, December 5, 2010 2:42:10 PM(UTC)
magician59
Refrigerators are made to work best at the midrange setting. Ideal fresh food temperature between 36-38 degrees. If you have to move the control to a colder setting to achieve this, there is something wrong. Perhaps you have something blocking the air flow. Check the damper and the return air vent (if there is one). Also make sure the evaporator fan is working (that's the fan in the freezer). Finally, make sure the condenser is free of dust, pet hair, and lint; and that the condenser fan is working.
rizzo692
#14 Posted : Wednesday, December 8, 2010 6:09:50 AM(UTC)
rizzo692
will check for all of the above will get back to you soon. thanks for all the advise.i do agree there must be something either blocking or wrong @this point.
2 Pages<12
