cjkms
#1 Posted : Friday, August 22, 2008 6:31:44 AM(UTC)
cjkms
Had problem with Gas oven not lighting. Broiler Works OK
Replaced Ignitor with p#WB2X9154. Worked one time then nothing. No glow. Rechecked both connections they are ok. Could it be a bad ignitor or something else. Did not drop or shake ignitor when installing. Thanks
libertyappl
#2 Posted : Friday, August 22, 2008 7:51:49 AM(UTC)
libertyappl
It's possible that it has a hairline crack causing it to work occationally and not other times.
