John Boyce
#1 Posted : Friday, August 15, 2008 7:19:10 AM(UTC)
John Boyce
I ordered the socket and bulb for my Frigidaire Model # GLEB30T8CBA and put them in. The light comes on when the door opens, however, the light switch button beeps but doesn't turn the light on. The socket did arc out when I tried to remove the original bulb. Maybe I wired it back wrong when I tried to fix it or maybe I need a new relay board or control panel. If so, what part number do I need to order? I see where there are 2 relay boards that can be ordered. I guess what I really need to know is: Will the light switch button still beep, and will the bulb still work when the door is opened, when the problem is the relay board or control panel?
libertyappl
#2 Posted : Friday, August 15, 2008 7:58:31 PM(UTC)
libertyappl
Which oven did you change the light socket in? Upper or lower?
John Boyce
#3 Posted : Friday, August 22, 2008 6:34:10 AM(UTC)
John Boyce
I changed out the upper socket. I now believe it is wired correctly because the wiring matches the bottom wiring. However, first the appliance person wired it up wrong and we lost all power and it smoked. I have replaced the AP2127302 relay board but now I don't have power showing on the front at all. Do I need to get a control board?
libertyappl
#4 Posted : Friday, August 22, 2008 7:38:42 AM(UTC)
libertyappl
If it's not your connections it is possible to be your control board.
Nat
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Frigidaire double oven sporadic issues (Oven Repair (including Ranges and Cooktops))
by Phil45 9/23/2015 3:32:55 AM(UTC)
Frigidaire Double Oven (Oven Repair (including Ranges and Cooktops))
by alttechnology 5/20/2013 9:11:16 PM(UTC)
Frigidaire double oven partially heats (Oven Repair (including Ranges and Cooktops))
by a029342 12/18/2012 10:48:46 AM(UTC)
Frigidaire double oven twin error codes F23 top and bottom (Oven Repair (including Ranges and Cooktops))
by mitchfix1 11/28/2008 5:46:37 AM(UTC)
Frigidaire Double Oven/ Top oven not heating (Oven Repair (including Ranges and Cooktops))
by dross3491 11/17/2008 9:04:56 AM(UTC)
F8 error Frigidaire double oven (Oven Repair (including Ranges and Cooktops))
by jps 12/18/2007 7:48:09 PM(UTC)
