Dryer will not power on after using it earlier today with no problems. Dryer inside light is working, so it has power. dryer will not work when pushing the start button.
Originally Posted by: lriddiford  Dryer will not power on after using it earlier today with no problems. Dryer inside light is working, so it has power. dryer will not work when pushing the start button. Take the back panel off the dryer, and replace the thermal fuse. It is white, and is a inch and a half long, by a half inch wide. It has 2 wires coming to it, and has one screw holding it in place. Tom ApplianceEducator.com
