Myers521@mchsi.com
#1 Posted : Wednesday, August 20, 2008 7:10:29 PM(UTC)
Myers521@mchsi.com
The burner ignitors are always firing. All control knobs are in the off position and no error codes are present on the display. :confused:
libertyappl
#2 Posted : Wednesday, August 20, 2008 7:23:24 PM(UTC)
libertyappl
Try to access the panel with the burn controls and disconnect each ignitor switch (follow the wires from the switches to where they come together unplug one side and see if the clicking stops then the other side do the same thing.
If they clicking stops the your switches are the problem if not it's your spark module.
post your results.
Nat
