Clothes are getting stuck between the drum and front panel and it burns or turns them black. I can tell the drum has slack because it will move up and down about a half inch in the front. What can I do please?
Probably the glides(slides) and upper bearing. without looking at a breakdown of parts. That would be my guess. Nat
Thanks. Could you possibly get me part numbers for these?
The upper is AP3156144 lower is AP2043044 It's best to change both of them. Hope that helps Nat
