When you press Bake Temp on control pad the oven doesn't ignite, it says on read out 100 degrees and says the oven is on but there is no flame. Then I could try it the next day and it might work. It's like a crap shoot. I bought oven ignitor but have not installed yet want to get an idea this is the problem, I don't have a meter to check the voltage to be sure. Thank you for the help.
okay Tom I will give myself some advice, don't ask the same question other people have asked here you will get no reply. So I will help myself by answering my own question, put the ignitor in and see what happens maybe it will work then you would have figured it out yourself and you will have no one to thank but yourself and I will never have to post on this board again I will be fine.
Originally Posted by: tommyd78  okay Tom I will give myself some advice, don't ask the same question other people have asked here you will get no reply. So I will help myself by answering my own question, put the ignitor in and see what happens maybe it will work then you would have figured it out yourself and you will have no one to thank but yourself and I will never have to post on this board again I will be fine. Tommy Boy. I would guess by now, you installed that ignitor, and are enjoying some good biscuits, with your eggs. The ignitor gets weak, and is not strong enough to open the gas valve. So, if you have not installed the ignitor...Go for it. Tom ApplianceEducator.com
