Dear Sir,
The dispencer for ice and water has stopped working after working on and off for two weeks.
There is also a constant clicking coming from the back of the control module, WKKT 0158-00-04. US model # R-101, when the compressor is not running!
Ice box is full and water supply OK...
Is there a fix and is the PC board easy to replace if it is the problem?
Any help would be greatly appericated
David
Can you get me the serial#
Your main board needs to be replaced, it is located behind the access panel on the back of the refer. It is very easy to replace,here is the board... Part Details - GE Main board assembly, part number: WR55X10552Now you can replace it yourself, of coarse you need to buy the part, or you could call GE at 1-800-432-2737 and schedule service. Cost for ge to replace the board is free if it is 0-3 years old, and $100 3-5 years old.
