5burnettes
#1 Posted : Tuesday, November 30, 2010 11:57:12 AM(UTC)
5burnettes
I recently replaced my timer because my washer would not agitate or empty the water, but the timer was going through its cycles. The new timer now works, but with one problem, when it gets to the spin cycle (in all 4 modes) water is pouring in the entire spin cycle. After the cycle is completed, the clothes are soaking wet, but there is no water standing in the tub, so its draining while pouring in. What could be causing this?????
#2 Posted : Tuesday, November 30, 2010 2:06:42 PM(UTC)
What is the complete model number of the washer?
What is the part number of the timer you installed?
5burnettes
#3 Posted : Wednesday, December 1, 2010 4:00:12 AM(UTC)
5burnettes
My washers Model # is LAT8306AAE.
The number on the box of the new timer is WPL 232002202.
Thanks,
#4 Posted : Wednesday, December 1, 2010 12:43:04 PM(UTC)
The part number you posted is incorrect. It suppose to be 8 digits and it's better to look for the part number on the timer or on the invoice for the part.
There are two different timers used for this washer depending on the serial number. So possible you replaced it with a wrong part. Post the serial number of the washer and I'll find the correct timer for your washer.
5burnettes
#5 Posted : Thursday, December 2, 2010 5:53:16 AM(UTC)
5burnettes
My Serial # is 15083928SH.
The part I originally ordered (timer) is WPL 22002202. I mis-typed the first time.
Thanks for your help!
#6 Posted : Thursday, December 2, 2010 11:58:25 AM(UTC)
This part number is incorrect. By the model and serial numbers you posted the correct part number for the timer is 22002184 which is Appliance Parts Pros Part number: AP4026744
P.S. I'm wandering how did you find this part number?
5burnettes
#7 Posted : Thursday, December 2, 2010 4:03:27 PM(UTC)
5burnettes
I was given it when I told the lady my model number and I needed a timer. That's the one I got.
Thanks again for your help with this!
