LittleWhite
#1 Posted : Wednesday, August 20, 2008 8:58:57 AM(UTC)
LittleWhite
Hello...
I have a fairly new dishwasher ( 4 years old) Performa... it says Maytag on the inside LR111720 is also there. The problem is that it stops washing.. the lights go out and then it restarts and the lights go back on. This goes on endlessly! Any advice?
Thank you :)
iamigor5@yahoo.com
#2 Posted : Wednesday, August 20, 2008 2:38:47 PM(UTC)
iamigor5@yahoo.com
sounds like a power problem the first thing i would do is turn off power at breaker then remove bottom toe panel you should see a silver box with a screw remove cover and check to see if you have a burnt wire there should be wire nuts connecting wires together make sure theyre tight hope this helps
LittleWhite
#3 Posted : Wednesday, August 20, 2008 3:38:29 PM(UTC)
LittleWhite
Since I'm "female" at that stuff... I will ask the neighbor guy to try that..TY for the advice!!
