sarahwhite914
#1 Posted : Wednesday, August 20, 2008 1:05:10 PM(UTC)
sarahwhite914
The washer just totally stopped working. I had just washed a load of clothes and put them in the dryer. I went to put another load in and the water would not turn on. I did not smell anything, the timer moves around fine, I selected the cycle and pulled the knob, and nothing. It's like I can hear the timer trying to work, but nothing happens. I moved the timer around, and it would not fill on a rinse cycle, or a delicate cycle, it doesn't do anything.
How can I fix this? I have already had this washer fixed like 4 times for other reasons, but I cannot afford to get it serviced again, and also can't afford to buy a new washer right now (and I have dirty clothes piling up!!!). Any insight into this will be very greatly appreciated.
Thank you.
libertyappl
#2 Posted : Wednesday, August 20, 2008 7:44:10 PM(UTC)
libertyappl
Change your water temp first. If it works then it's the valve. If not it could be a number of problems.
Check your water valve on the back it may have clogged up, or you may need a new one Whirlpool part number is 285805 (AP# AP3094541). If in doubt go to a recycling center to see if they have any Whirlpool washer setting around and talk them out of a couple of water valves ;o)
Hope that helps
Nat
sarahwhite914
#3 Posted : Thursday, August 21, 2008 5:51:23 PM(UTC)
sarahwhite914
I did not try it yet, but I do thank you for your reply.
