alexp1322
#1 Posted : Wednesday, December 1, 2010 5:17:20 PM(UTC)
alexp1322
My did washer shut off during the cycle. I open the door and water was in the bottom of it. I took the filter off and found a piece of the rack in the bottom of the drain. Now why will my washer not turn back on?
#2 Posted : Thursday, December 2, 2010 1:33:41 AM(UTC)
Replacement parts for WHIRLPOOL DU1055XTPQ3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
The thermal fuse (Item 6 in Section 2) may have blown.
The motor would have pulled more current when it was jammed.
Open the door up and check it with a meter, should be 0 ohms.
If blown be sure to use the new wiring harness that comes with it.
Whirlpool dishwasher won't turn on (Dishwasher Repair)
by beginner 12/27/2007 7:31:28 AM(UTC)
