2 Pages12>
bill1943
#1 Posted : Wednesday, December 1, 2010 2:03:06 PM(UTC)
bill1943
I have an electrolux double wall oven. The bottom element, in the top oven is not working. I've replaced the element but the problem is the same. I don't have a wiring diagram,so I don't know what to do next,or if the problem is with a thermal fuse,control panel or ?. Can anybody give me some advice ? Thanks, Bill
#2 Posted : Wednesday, December 1, 2010 2:50:09 PM(UTC)
Bill,
Does the top (broil) element in this oven work?
bill1943
#3 Posted : Wednesday, December 1, 2010 3:03:15 PM(UTC)
bill1943
Bill,
Hello Gene,The top (broiler element does work
bill1943
#4 Posted : Wednesday, December 1, 2010 3:05:48 PM(UTC)
bill1943
Bill,
Hello Gene,Yes the top (broiler element works fine.
bill1943
#5 Posted : Wednesday, December 1, 2010 3:15:14 PM(UTC)
bill1943
Hello Gene,I'm not sure if I'm replying to you correctly,but the broiler element does work correctly
#6 Posted : Wednesday, December 1, 2010 4:06:21 PM(UTC)
There is a thermal circuit beaker but it will shut off both Bake and Broil elements. So the problem is a bad relay board for the upper oven. It is located inside the control compartment and the oven has to be removed from the cabinet to access the part.
- The upper oven relay board Part number: AP2127302
bill1943
#7 Posted : Wednesday, December 1, 2010 5:40:53 PM(UTC)
bill1943
Hello Gene,Thanks so much for the info. I didn't have a wiring diagram,so I just didn't know what part would allow the broiler element to work and not the lower bake element. Thanks again for your help, Bill
#8 Posted : Thursday, December 2, 2010 10:43:10 AM(UTC)
You are welcome Bill. Keep us posted.
bill1943
#9 Posted : Thursday, December 2, 2010 10:58:24 AM(UTC)
bill1943
I can't thank you enough, Bill
bill1943
#10 Posted : Sunday, December 5, 2010 12:09:02 PM(UTC)
bill1943
Hello Gene,I wanted to let you know that I replaced the relay board for the top oven and it now works perfectly!! Thanks again for your advice.I think I probably saved $400-$500 by doing it myself. Bill1943
Guest (8)
2 Pages12>
