clubmaker
#1 Posted : Wednesday, December 1, 2010 12:34:32 PM(UTC)
clubmaker
I replaced the control module on my Bosch SHU4306 dishwasher and I am trying to put the door back together. There are 2 parts, the door and the top piece which holds the control module.
Which one should I screw in 1st. The door or the top piece. It seems like I need about 4 hands to accomplish this. Any help is appreciated. Thanks
John
#2 Posted : Wednesday, December 1, 2010 2:10:06 PM(UTC)
John,
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for Bosch SHU4306 UC/11 (FD 8001-8003) | AppliancePartsPros.com
Handles attachments
How to replace control module.doc (130kb) downloaded 66 time(s).
clubmaker
#3 Posted : Saturday, December 4, 2010 1:51:50 PM(UTC)
clubmaker
John,
Thanks Gene, I got it all back together and thanks to everyone else on the forum explaining the control module replacement.
It was very easy to replace the module, but a little tricky getting the door back on by myself, it would of been easier with two people.
hanginthere
#4 Posted : Thursday, December 9, 2010 11:09:09 AM(UTC)
hanginthere
used the instructions to locate and repair bad solder connection on control board. Worked like a champ.
I see this has been an issue for a long time. Recall??? board appears overheated by current not cold solder.Bad design??
How many poor bastards don't run across this fix and spend ridiculous $ on the repair. Bosch is supposed to be 1 of the best brands.
JA
pridbor
#5 Posted : Thursday, December 30, 2010 10:28:24 PM(UTC)
pridbor
I'm in the process of fixing the red wire soldering on the Control Module, and have seen a reference to a Test Program. Can somebody please shed a little light as to how to invoke this? Thanks in advance Pridbor
