scolson
#1 Posted : Wednesday, December 1, 2010 9:36:37 AM(UTC)
scolson
Whenever we press the start button on our dryer you can hear a clicking noise (relay?) from inside the control panel, but the dryer never starts. Also, If I open the front door after selecting the start button I hear another click. So, I think the door switch is working. I would like to check the thermal fuse, but I'm not sure how to remove the covers. Can anyone help me?
scolson
#2 Posted : Wednesday, December 1, 2010 1:01:53 PM(UTC)
scolson
the thermal fuse was bad, replaced and now the clicking noise is gone. However, when i select start, the drying led is on, but the drying is not spinning or heating
#3 Posted : Wednesday, December 1, 2010 2:26:46 PM(UTC)
Remove the front bottom access panel and check the belt and the broken belt switch (#5 on the diagram, under the idler pulley).
- The belt Part number: AP2911808
- The broken belt switch Part number: AP3094230
- The control board Part number: AP3841286
