Our Frigidaire gas range top burners will no longer ignite using the built in igniter's, no "Popping" or ignition sound comes from any burner control but we can light burners with a match. The strange part of this problem is the oven also stopped working the same time the cook-top ignitors stopped working. I suspect that it is the #316135701 spark module is bad, but am unsure if the oven is dependent on the spark igniter for proper operation :confused:.
Does anyone know if the spark module has anything to do with the ovens operation?
Joined: 5/28/2008(UTC) Views messages in topic : 1,620
The oven does not go through the spark module for the cooktop. Can you verify there is voltage to the range?
Yes, the clock and oven light are working fine? Coincidence and unrelated perhaps? Could it be the control board instead? Thanks!
Jerry
