ddenn
#1 Posted : Sunday, August 17, 2008 9:09:39 AM(UTC)
ddenn
My refrigerator will run fine for a couple of days then it will get warm.
I move the temp control both ways to get it to start again. Also it seems to run for a long time between cycles.
Thank you in advance!
#2 Posted : Sunday, August 17, 2008 10:23:13 AM(UTC)
Measure the back wall freezer temperature and post.
ddenn
#3 Posted : Sunday, August 17, 2008 10:29:30 AM(UTC)
ddenn
The back wall temp is 6 deg.
Thanks!
ddenn
#4 Posted : Sunday, August 17, 2008 9:01:44 PM(UTC)
ddenn
When I got home tonight the refrigerator was again warm. The temp on the back wall of the freezer was 34 degrees.
#5 Posted : Monday, August 18, 2008 1:30:06 AM(UTC)
When the fridg fails, check to see what is running/not running.
ddenn
#6 Posted : Wednesday, August 20, 2008 8:17:42 AM(UTC)
ddenn
Nothing is running. The lights come on, that's it.
abadfish66
#7 Posted : Wednesday, August 20, 2008 8:28:06 AM(UTC)
abadfish66
Sounds like either the timer gets stuck in defrost too long, or the termination thermostat (round device clipped to the upper part of the evaperator) is bad. You can visually check the thermostat by removing the rear panel in the freezer section and see if the top of the disk is pushed up out of the device. Also alot of times the timer will make a ticking noise if it is going bad.
