rubywls
#1 Posted : Tuesday, November 30, 2010 2:27:17 PM(UTC)
rubywls
my dryer comes on and stays running for abou 40 minutes then quits running. when it cools off it will start back up. whats wrong? its driving me crazy.
#2 Posted : Tuesday, November 30, 2010 6:17:22 PM(UTC)
Possible the motor is dying. The model number you posted does not come up. Verify and repost it please.
#3 Posted : Wednesday, December 1, 2010 5:05:34 AM(UTC)
As Gene said it sounds like the motor is overheating.
Check that the motor and it's cooling fins are not clogged with lint.
I had one a while ago that the blower housing seal was shot and it was blowing hot air back onto the motor causing it to overheat.
It is also a good time to clean/check your vent system.
