I just got done repairing my dryer. Replaced the 2 drum rollers,idler wheel and belt.I downloaded the belt diagram to route the belt,but it doesn`t apply to my model SDE515DAYW..The motor drive shaft is bellow the idler wheel which make it imposible to route to belt around the drum with the ribs facing away from the drum.
THIS FORUM IS DEAD!!!!!!! |
I cannot say what is going on. They may well have modified the idler and not updated the diagrams.
The ribs must face the motor pulley because it is ribbed to accept them. |
Looking at my dryer with the front off ,the motor is on the right side ,below the idler wheel on the left.The drum is above both.
