2 Pages12>
rizzo692
#1 Posted : Monday, November 29, 2010 12:40:12 PM(UTC)
rizzo692
CAN ANYONE HELP ME WITH THIS COLD SETTING PROBLEM? I HAVE THE REFRIGE SIDE SET TO LEVEL 8 AND THE FREEZER SIDE SET TO LEVEL 5 MID LEVEL JUST TO KEEP THE FOOD IN MY FRIDGE COLD ???? IS THERE MAYBE A FREON CHARGE OR SOMETHING I HAVE TO DO SINCE IT'S GETTING OLD? OR MAYBE SOMETHING ELESE CAUSEING IT TO RUN OFTEN AND HAVE TO JACK THE LEVEL SO HIGH TO 8? ANY HELP WOULD BE GREAT..THANKS IN ADVANCE.:confused:PS: AND THE COLD WATER IN THE DOOR NEVER WAS COLD FROM DAY ONE EITHER.ANYONE HAVE THIS PROBLEM ALSO?
magician59
#2 Posted : Monday, November 29, 2010 1:05:35 PM(UTC)
magician59
This may be an air flow problem. Open the freezer when you hear the machine running, and see if the evaporator fan is running. Also see if the condenser fan is running. Check to make sure the damper and return air duct are free of obstruction or blockage. What is the temperature inside the freezer?
magician59
#3 Posted : Monday, November 29, 2010 1:07:13 PM(UTC)
magician59
This may be an air flow problem. Open the freezer when you hear the machine running, and see if the evaporator fan is running. Is the condenser coil free of lint? Check to make sure the damper and return air duct are free of obstruction or blockage. What is the temperature inside the freezer?
rizzo692
#4 Posted : Tuesday, November 30, 2010 10:24:53 AM(UTC)
rizzo692
I Will Check For Blockage..don't See Much There. Just I Might Have Some I Bet Maybe Under The Refridge Maybe Due To Cat Hair Build Up?? Will The Coil Thats Under The Fridge If Clogged Cause This Cold Problem? Or Could This Be A Freon Problem What So Ever? Just Trying To Seperate The 2. Will Advise On A 24 Hr Reading Temp Of Freezer On Weds. Thanks
magician59
#5 Posted : Tuesday, November 30, 2010 10:38:12 AM(UTC)
magician59
The condenser coil is the place where the refrigerator transfers the heat from the inside to the outside. If it's insulated by dust, lint, cat hair, or anything like that, its efficiency can be significantly reduced.
rizzo692
#6 Posted : Tuesday, November 30, 2010 11:37:39 AM(UTC)
rizzo692
So The Comdenser Coil Is Uder The Refrige Correct?? And It Does Blow Out Some Hot Air Under The Refridge While Running. What Would Be The Best Methed In Trying To Clean The Coils Or Grid Under The Refridge? I Have A Shop Vac. Just It's Heavy To Lift...please Advise Thanks
magician59
#7 Posted : Tuesday, November 30, 2010 12:11:44 PM(UTC)
magician59
Yes. the condenser is under the refrigerator. This is a very good brush. When you push it into the coil and pull it back out, most of the lint clings to the brush.
Part number: AP4320046
rizzo692
#8 Posted : Tuesday, November 30, 2010 12:56:23 PM(UTC)
rizzo692
Well Well Now This Brush Looks Like It Will Do The Trick. I Can Pick This One Up At My Local Supply House. I Hope Some Cleaning Of Debris Will Restore Some Cold Back To My Refridge? I Will Let You Know Weds On Temp In Freezer. Will Advise. Thanks Again
rizzo692
#9 Posted : Wednesday, December 1, 2010 6:19:41 AM(UTC)
rizzo692
Freezer Update Temp. Just Checked And Was Below Zero. Good Or Bad? It Was Just Under The Zero Mark???
magician59
#10 Posted : Wednesday, December 1, 2010 6:35:54 AM(UTC)
magician59
Sounds ideal. Check refrigerator temperature; With controls set to mid-range, it should be somewhere near 38 degrees.
2 Pages12>
