Marc Anderson
#1 Posted : Monday, November 29, 2010 4:32:45 PM(UTC)
Marc Anderson
My Cabrio dryer will not finish drying the load. The vent is clear. The gas burner will light and run for awhile but will not dry clothes compleatly. There is a "Sensor Pad", part # 8576468 mounted in the back of the tub and I am wondering if this could be my problem. Is there any way to test this theory?
kayakcrzy
#2 Posted : Tuesday, November 30, 2010 4:06:41 AM(UTC)
kayakcrzy
Marc, it sounds like the coils on the gas valve are your problem. They are cheap, and an easy repair. Alot of times the heat will come on the first time , and not after it cycles off. This is a very common problem. Tom ApplianceEducator.com
