edwcher
#1 Posted : Tuesday, August 19, 2008 1:38:44 PM(UTC)
edwcher
I have a similar problem of a warm refrigerator section and a cold freezer.The problem is I cannot find a breakdown diagram for the model I have which is Amana Model #ABB2227DES.Your help wlll be greatly appreciated.
libertyappl
#2 Posted : Tuesday, August 19, 2008 7:09:17 PM(UTC)
libertyappl
Sounds like a defrost issue or a damper issue. For a breakdown of the unit try sears parts direct they will have a breakdown but parts are generaly a lot higher.
Nat
edwcher
#3 Posted : Wednesday, August 20, 2008 5:21:10 PM(UTC)
edwcher
Thanks very much for your prompt response to my inquiry.I was not able to find the unit breakdown in Sears parts direct,it came up with the Customer Manual that is supplied with.the frig.With time running out I was able to find an Appliance Repair outfit with a very capable technician. The evaporator coil was completely frozen, and the main circuit board(Control Board Kit) was defective and replaced.
libertyappl
#4 Posted : Wednesday, August 20, 2008 5:50:31 PM(UTC)
libertyappl
