my dishwasher will run through a complete cycle. then will continue running unless i open the door. took the timer out closed the door dishwasher still runs. whats going on.
Originally Posted by: waynemcd1  took the timer out closed the door dishwasher still runs. whats going on. If you're dishwasher is running on a timer and you've properly removed this from the circuit, I guarantee you that it will not run. If it's still running after you've removed the timer, call ghost busters. Your timer motor is shorted. Replace the timer.
