First Post; hello all. Loud intermittent squeal. belt ok, have ordered rollers, glides, and pads from APP. (I am aware that Admiral is Maytag that uses some Whirpool etc.) If this don't fix it need suggestions. Thanks
Could also be the motor bearings or the idler wheel. Odds are one of the parts you ordered is the cause.
Check the idler wheel for slop and any signs that it is rubbing on the side of the shaft holder.
Also check the motor bearings for slop and give the armature a spin. A drop of oil on theses bearings will not hurt. Do not use WD-40 use a good oil like sewing machine or 3 in1 oil etc. Do not go crazy with the oil as it will act like a dust magnet.
Also check the blower, could be something has fallen in there or the wheel is off kilter for some reason.
It is also a good time to clean/check your vent system. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Could also be the motor bearings or the idler wheel. Odds are one of the parts you ordered is the cause.
It is also a good time to clean/check your vent system. Thanks Denman, the additional info is appreciated. Will give follow-up when parts get here and I do repair.
Originally Posted by: composter7  Thanks Denman, the additional info is appreciated. Will give follow-up when parts get here and I do repair. Denman, I have SAE 20 "Motor Oil" made by 3in1. Is it ok for this purpose?
Originally Posted by: composter7  Thanks Denman, the additional info is appreciated. Will give follow-up when parts get here and I do repair. Denman, Repair complete....did what you suggested. Just slight noise every now and then, probably new glides seating. Thanks again. A once noisy 'Admiral' went from one star (*) to four (****).
