Tony Seaton
#1 Posted : Monday, August 18, 2008 7:47:18 AM(UTC)
Tony Seaton
KitchenAid Trash Compactor
Model No. Kucc151lpa0
The spring is broken on the foot pedal. Do I need
part 2 in the diagram is called the actuator switch or
part 7 foot pedal?
#2 Posted : Monday, August 18, 2008 11:03:13 PM(UTC)
Tony,
Check the container spring (#33 on the break down diagram).
Check how freely is container moving forth and back. Check if the container is not bend.
The foot pedal is not spring loaded.
