jmichelle24
#1 Posted : Monday, August 18, 2008 1:48:52 PM(UTC)
jmichelle24
My freezer and fridge will not stay cold. I have unpluged it to reset it and it will freeze for a day or two then stop. Whats the problem with my refridgerator or is it time to replace it. I have owned this one for 8 yrs. Help Please!!
libertyappl
#2 Posted : Monday, August 18, 2008 1:51:45 PM(UTC)
libertyappl
Can you elaborate on this a bit? How long was it unplugged? Can you put a thermometer in the frezzer & frig and post those readings?
Nat
jmichelle24
#3 Posted : Monday, August 18, 2008 2:06:28 PM(UTC)
jmichelle24
The first time I left it unplugged for a 24 hrs then the second time i left it unplugged for 8hrs.... Not sure of the temperature inside the fridge guess around 50 because everything is thawing out from top of fridge to bottom
libertyappl
#4 Posted : Monday, August 18, 2008 6:48:15 PM(UTC)
libertyappl
In the freezer side, remove the lower panel, held on by 6 screws, and see if you have a lot of ice buildup there. Is the fan in the freezer running?
Nat
