Three out of the four gas burners are working. When attempting to turn on the burner that is not work, it just clicks. Any suggestions? Thank you for your time in advance.
Dose it spark at the burner or it just clicks?
What is the complete model number of the range?
Hey Gene,
I can't see if it sparks, I'm going to assume that it doesn't since I can light it when I put a match next to it. The model is GE Spectrum XL44. Reading through this forum, I suspect it's the ignitor.
Most likely the problem is a bad igniter. Look for the model number on the frame, behind the bottom drawer.
