davidjones
#1 Posted : Wednesday, November 24, 2010 11:12:57 AM(UTC)
davidjones
sounds like I am having a common problm I have tested the heater,waiting to freeze to test the temp control, can not find the timmer. what part number do I need for the Thermostat and will i have to cut wires to install it?
#2 Posted : Wednesday, November 24, 2010 12:27:31 PM(UTC)
Replacement parts for AMANA AFD2535DEB Ref - Bottom Mounts | AppliancePartsPros.com
Your defrost is run off the control board.
I could not find a manual for your specific model but the following may be close.
16025629 Maytag Amana Bottom Mount Refrigerator Service Manual - ApplianceDigest.com
You may have to join the site but it is free and is a great site for appliance info.
The defrost thermostat can be checked by holding the metal face on an ice cube. Also if it looks bulged/deformed replace it even if it read OK on your meter.
Here is the defrost thermostat
Part number: AP4078076
Click on the picture for more info.
Does look like you will have to splice it in.
I would use the ceramic/hard plastic type wire nuts.
They are more heat resistant.
Once spliced in position them away from the heater and facing down so that water cannot enter them.
Some techs like to seal the open end with caulking.
davidjones
#3 Posted : Wednesday, November 24, 2010 3:46:57 PM(UTC)
davidjones
does the thermostat read open or closed when frozen?
#4 Posted : Wednesday, November 24, 2010 6:31:19 PM(UTC)
Closed when frozen.
Should open just above freezing.
