Hi, I have a Thermador PGR304ZS oven range that is about 2004-5 vintage. My problem is on the side of the stove that has the normal burners, not the XLO simmer ones. When I turn on either burner on that side, both igniters spark and then only the burner that was turned on stops sparking after it is lit. The other burner keeps sparking until the lit burner is turned off. It does not matter which of the two burners that I light, the other continues to spark until the lit burner is turned off. If I light both, then both igniters turn of correctly. I changed out the igniter module, but that had no effect. I also changed out the microswitches on the knobs and that had no effect. Thanks Mark Tangney
Thanks Gene,
I read the thread and did everything in there except replace the wires. I polished the burner components and got good continuity to ground. I replaced the two igniters, I checked both wires, the wires and insulation look very good, and tested for resistance and everything came up fine. I don't know what else to try.
Thanks Mark Tangney
Originally Posted by: mtangney ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks Gene,
Thanks Mark Tangney Mark, Sounds like the ignition (spark) module you replaced is defective. It has to be exchanged due to the parts warranty by the people who sold it to you. - The spark module Part number: AP2825261
The manufacturer part number is 189024. Gene.
