c grass
#1 Posted : Tuesday, November 23, 2010 5:26:01 AM(UTC)
c grass
I have a Roper 29' dryer and the heating element won't start. I've replaced the heating element and thermal fuse, after this didn't work I went through the rest of the limit switches to check for continuity and none we're bad........any suggestions?
#2 Posted : Tuesday, November 23, 2010 5:53:21 AM(UTC)
Check the power into the unit.
Timer, motor etc. all run on 120 volts but the heating element requires the full 240 volts.
It is not uncommon to loose half the line without actually tripping the breaker.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
c grass
#3 Posted : Tuesday, November 23, 2010 9:25:51 AM(UTC)
c grass
If OK
If OK
Thank you so much for responding, didn't even think to turn breaker off and on. that is exactly what happened....... power went out during a storm few days back. Thanks again!
#4 Posted : Wednesday, November 24, 2010 3:34:55 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
