Jack D W
#1 Posted : Monday, November 22, 2010 1:37:37 PM(UTC)
Jack D W
Convection fan wont run on normal conv.oven operation. Everything else on range OK. I've applied external power to the red wire on the P15 plug on the H1 Gas circuit board At top of range and fan runs fine. Any ideas?:)
#2 Posted : Monday, November 22, 2010 5:31:19 PM(UTC)
Sounds like the control board is the culprit.
- The control board Part number: AP4099351
Jack D W
#3 Posted : Tuesday, November 23, 2010 7:49:57 AM(UTC)
Jack D W
Thanks Gene, however when I put everything back the fan is working. I must have disturbed something! I'll keep your suggestion in mind if it goes again.
