3 Pages123>
jcsaxx
#1 Posted : Monday, November 22, 2010 9:04:14 AM(UTC)
jcsaxx
A couple days ago, my son did a load of laundry and washed a pillow. Since then, the washer will not drain or spin. The washer will still agitate and will fill with water. All the machine does after agitating is, I hear a clicking noise of the timer.
When agitating the motor moves the belt, so that should mean both the belt and motor are good, right???
We have been finding parts of the pillow stuffing around the washing "bowl", but not inside at all. We did take off the outer hose and the water all drained out, but didn't see of the pillow stuffing come out. I'm guessing the problem has to be related to washing the pillow, because of the timing of the machine messing up right afterwards.
So we are stuck going to the laundry mat until we figure this out.
Please help. I don't have anything to check the voltage or anything like that. I have tried the "trick" of unplugging power for 1 minute, then plugging it in, then opening and shutting the lid 6 times in 30 seconds.
MODEL #: wbsb3140daww
magician59
#2 Posted : Monday, November 22, 2010 9:07:35 AM(UTC)
magician59
What's the model number?
jcsaxx
#3 Posted : Monday, November 22, 2010 9:23:29 AM(UTC)
jcsaxx
wbsb3140daww
magician59
#4 Posted: : Monday, November 22, 2010 9:37:25 AM(UTC)
magician59
It sounds like you have a clogged pump. If it is clear,you may have a bad motor or a broken transmission. I don't have any experience with the "clutchless" motor, but if it follows tradition, the transmission is the culprit.
Part number: AP3160348
jcsaxx
#5 Posted : Monday, November 22, 2010 9:54:19 AM(UTC)
jcsaxx
Pardon the question, but if it was the agitator coupling, would the machine NOT agitate at all?
Please explain if you can.
magician59
#6 Posted : Monday, November 22, 2010 10:36:05 AM(UTC)
magician59
EXPLANATION: That post was edited out.
jcsaxx
#7 Posted : Monday, November 22, 2010 11:03:49 AM(UTC)
jcsaxx
So if the pump is clogged (won't know until I figure out how to take it apart), the motor won't turn the belt at all, right??? I have no idea what I'm doing, so pardon all the questions. Want to narrow it down as much as possible.
Heading to work.
Thanks for your help.
magician59
#8 Posted : Monday, November 22, 2010 12:08:32 PM(UTC)
magician59
Your pump is electric. It's located in the cabinet toward the back right. You'll be able to identify the component by the drain hoses attached to it. A quick way to check to see if it's clogged is to take the drain hose out of the stand pipe and lower it to a level below that of the water in the tub. If water trickles out, or no flow at all, you'll likely have to replace it. This isn't 100% reliable, as water can possibly flow through the pump, and still the impeller can be clogged.
Here's a parts breakdown that shows the general construction of your machine. To open the cabinet, notice the spring clips about 4 inches from each front top corner (the machine top; not the console). While lifting each respective corner, push in against the clip with a flat tool (like a putty knife) until that corner releases. This will expose the screws that hold the front panel in place.
Cabinet, cover & front panel replacement parts for General Electric WBSR3140DAWW Washer | AppliancePartsPros.com
jcsaxx
#9 Posted : Sunday, November 28, 2010 11:45:10 AM(UTC)
jcsaxx
So the problem was that part of the pillow stuffing was clogging the pump. Pulled out the stuffing and now the washer is working. So far, testing is going very good. It's draining and spinning.
magician59
#10 Posted : Sunday, November 28, 2010 5:17:59 PM(UTC)
magician59
Great to hear you didn't need parts...Well done!
3 Pages123>
