ref. making constant clicking sound from circuit board .compressor is hot . fan does not run. ref. & freezer not cold enough.IS the problem with the board,comp. or fan.:confused:
It is your board without a doubt
Originally Posted by: abadfish66  It is your board without a doubt thank you for pointing me in the right direction.:)
minty, The part number for the main control board is AP3950129 and you can buy it from APP for just $85.16 Gene.
