smityy25
#1 Posted : Sunday, November 21, 2010 8:14:25 AM(UTC)
smityy25
My fidge is freezing food on fridge side. Prior to freezing the fan on bottom was making griding noise and now it does not spin any more. Could the fan not be cooling anymore causing my fridge to freeze everthing. What part or parts do i need to fix.
#2 Posted : Monday, November 22, 2010 2:33:41 AM(UTC)
Replacement parts for WHIRLPOOL ED5CHQXKQ03 Refrigerator | AppliancePartsPros.com
If you mean the (evaporator) fan in the freezer then yes it can cause your problem, See Item 7in Section 10.
There will be no air circulation so cold air will settle to the bottom of the compartments.
Eventually the freezer temperature will rise.
smityy25
#3 Posted : Monday, November 22, 2010 7:01:05 AM(UTC)
smityy25
denman, thanks for the response. It is not the fan in the freezer it is working fine, it seems to be on alot or all the time(freezer is very cold). The fan i was referencing is the one on the bottom (section 9 item 24) condensor fan. I have the controls set to lowest setting for the freezer and fridge but still freezing in fridge. Could this condensor fan be the reason the freezer is venting so much cold air to fridge side? And controls not working?
#4 Posted : Monday, November 22, 2010 8:16:17 AM(UTC)
I would check the temperature in the freezer.
It should be 0 to 5 degrees F.
If it is lower then probably your thermostat (Item 9 in Section 11) is shot.
Also could be that the fresh food control is not closing the louvers in the damper (Item 24 in Section 2) which regulates the amount of cold air that enters the fresh food side.
Also make sure that the lower vent between the sections are clear of food items etc..
[COLOR="Blue"]
Could this condensor fan be the reason the freezer is venting so much cold air to fridge side? And controls not working?[/COLOR]
I doubt it but it will make your compressor run much more as the heat is not being dissipated from the condenser coils very efficiently.
I would replace it ASAP as it is also hard on your compressor since the compressor will run hotter.
smityy25
#5 Posted : Monday, November 22, 2010 9:44:01 AM(UTC)
smityy25
what controls how the louvers close in the damper? Is this an electric part or manual?
#6 Posted : Monday, November 22, 2010 12:41:18 PM(UTC)
Looks manual to me.
If you click on the picture of the part a new page will open, often with more views. You can then click on these to expand them.
Clicking on the damper I cannot see any evidence of a thermostat control.
Guest (6)
