Originally Posted by: Raydecraene  No Bake element heat.
Rebuilt control module new sensor new bake element No Fault codes set to 350 - no heat - resets to 100 and that is it Broil works Ray, Have you checked for 220 VAC at the bake element in a Bake Mode ? That's the only thing left, a broken or damaged wire to the element. You'll need to remove the oven from the cabinet, so you can remove the back panel, and have acces to the wiring harness and junction box so you can check for damaged wires. Good Luck, :cool: :cool: :cool:
