My dryer stopped working in the middle of a run. All thermostat/thermal fuses and the door switch checked out ok. The timer control sounded as if it might have gone bad since it made a faint buzz when pushed in at the correct spots on the dial but would not actually start. However, with the replacement timer (53-1303) I just received there is no response at all. Is there a simple way to tell if the replacement timer also is faulty or is there something else I should check?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Originally Posted by: bmille ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My dryer stopped working in the middle of a run. All thermostat/thermal fuses and the door switch checked out ok. The timer control sounded as if it might have gone bad since it made a faint buzz when pushed in at the correct spots on the dial but would not actually start. However, with the replacement timer (53-1303) I just received there is no response at all. Is there a simple way to tell if the replacement timer also is faulty or is there something else I should check? Are you sure you have 240 volts at the dryer? If so did you check the thermal fuse next to the heating element? Part no. 6 of this diagram Heater (rev. e)(alm) replacement parts for NORGE DEM205A Dryer - Ele | AppliancePartsPros.com
Originally Posted by: ThatGuy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you - I have rechecked that there are 240 volts coming in at the back of the dryer. I also rechecked the thermal fuse by the heater element as well as the other 2 down closer to the motor - all give me "0" on the ohmeter at room temperature. This time through I also checked the resistor on the timer control and it is giving me a reading pretty close to the expected 3.77K. Any other suggestions of what I might try for diagnosis or to try replacing based on likely problem would be appreciated.
