I need to replace the belt & hope thats all to cure a squeel when the high speed spin starts. Looked at the back and dont think that is the way in. REMOVED 2 SCREWS AT THE BOTTOM but cant get anywhere. Thanks Bob
Hi Bob, In order to access the belt as well as many other parts inside you have to remove the front panel. Remove the two screws on the bottom of the front panel (#41 on the diagram), slide the front panel down and pull it toward yourself. - The belt Part number: AP3867042
