Hi all. My washing machine started leaking from the bottom near the front. It is probably a quart per load. I know its old and I should replace it, but that is not possible at this time. any suggestions before I get out the tools and disable this thing for a week?? I am real handy with machines ( Im an oil burner tech by trade) so dont be afraid to lay it on me! Thanks so much. Ron
It's probably your pump, usually a quick easy fix. Raise the top and remove the front panel and your can access it and be up and running again in less than 30 min (once you have the part)
Nat
