03Skip03
#1 Posted : Monday, November 15, 2010 2:56:06 PM(UTC)
03Skip03
Refrigerator and Freezer are warm.
I replaced the temperature control (wci5304404821) about one year ago. Could there be other problems or do I need to replace this again.
Thanks Skip :confused:
#2 Posted : Tuesday, November 16, 2010 3:28:16 AM(UTC)
Replacement parts for FRIGIDAIRE FRT21INLHB3 Frg(v1) / Refrigerator | AppliancePartsPros.com
[COLOR="Blue"]Could there be other problems or do I need to replace this again.[/COLOR]
I cannot say you need to do some troubleshooting.
If the unit/compressor is cycling properly then it probably is the thermostat.
If it is running constantly except when in defrost then it may be a defrost problem or a sealed system problem.
Best way to check is remove the cover in the freezer and inspect the coils for ice/frost.
Heavily iced/frosted over is a defrost problem.
No frost or frost only in one area is a sealed system problem.
