diane56
#1 Posted : Monday, November 15, 2010 9:40:30 AM(UTC)
diane56
Our dishwasher is suddenly non-functional. It acts like it has been unplugged (it has not), the child lock is not on, the lights on the front panel are out. Any ideas on a fix without calling inthe service people again? I feel like we got a lemon. This is the 3rd major problem this kitchen aid has had in 5 years. I've paid alot of money for repairs and wonder if it is time to change brands all together.
#2 Posted : Tuesday, November 16, 2010 1:51:35 AM(UTC)
Replacement parts for WHIRLPOOL KUDI01ILBL1 Undercounter Dishwasher | AppliancePartsPros.com
Sounds like the thermal fuse is blown (Item 6 in Section2).
If it is be sure to use the new harness that comes with the fuse.
diane56
#3 Posted : Tuesday, November 16, 2010 8:53:58 AM(UTC)
diane56
Is there a way I can test to make sure it is the fuse? Thanks
#4 Posted : Tuesday, November 16, 2010 10:17:16 AM(UTC)
Yes.
Remove power from the unit. Unplugg one side of the fuse and measure it with a meter.
Should be 0 ohms.
diane56
#5 Posted : Wednesday, November 17, 2010 7:08:42 AM(UTC)
diane56
I do have a multimeter but where is the thermal fuse located? Is it the tan or black wire leading into the door switch? I see one yellow wire but it is with 4 other wires on the far right hand side of the upper control panel. I have looked at the lower control panel behind the kick plate but don't see it there?
#6 Posted : Wednesday, November 17, 2010 9:33:04 AM(UTC)
Look at the parts breakdown (item 6 in Section 2), main control board in the door, may be on the board or on a harness.
