A belt was placed in the washer and broke a plastic vane (Part Number FR131274600) How does the vane come out? I have removed the screw but the tabs seem to have a good grip and I don't want to bend the drum. Please help. Two teenage daughters and the clothes are piling up!!!!!
Once the screw is removed, you should be able to slide it either to the rear or front and it will come out. If it still wont come out, there is a tab on the other side of the basket that has to be bent up to unlock it, and that is a very big job. If that's the case, I would just start breaking the vane apart to get it out of there.
