Lady says it drops in and out on spin. Seems like a bad motor/inverter Part # WH20X10045. Hope someone knows about this less than 2 year old washer. Thanks in advance.
What is the led on the invertor doing?
Will look at the washer on Friday. She says it works ok in agitate, just drops out in spin. If the LED is solid is this a bad inverter??
When motor is operating normally, and running, the LED blinks at a constant rate of ½ second on and ½ second off.
When motor is operating normally, and idle, the LED blinks at a constant rate of 1 second on and 1 second off.
Motor/Control error condition - LED is on for .25 seconds and off for .25 seconds for a specifi ed number of times, during a 6-second period. The 6-second cycle repeats continuously.
1 second on 1 second off---normal .5 sec on .5 sec off--------normal 1 flash--------------------long stop time------replace motor 2 flash--------------------slipping belt--------check belt 3 flash-------------------corrupted software---replace motor 4 flash-------------------mode shift circuit failed-check mode shifter coil 5 flash-------------------not known-----------replace motor 6 flash------------------locked rotor----------make sure system is free 7 flash-----------------lid switch did not open---check lid switch 8 flash-----------------motor overheated------make sure system is free 9 flash----------------brake resistor open------replace motor on 2,4,6,7 & 8 flash errors, if no system error are found replace motor. Critical Errors, #1, #2, & #7, will prevent inverter/motor from operating.
To clear errors, disconnect power until an audible clicking sound is heard when the inverter capacitor discharges (approximately 15 seconds). Open and close the lid 5 or more times in any 12-second period within the first 30 seconds of power-up. Errors will not clear if washer is in either agitate or spin mode.
Thanks for the info, will test Friday.
