tyrone09
#1 Posted : Friday, November 12, 2010 9:18:02 AM(UTC)
tyrone09
Hi, My dryer is not working. I have checked for power - I am getting power from the wall out let and power at the back of the dryer (thermainals) but the dryer is still not working, can it be the timer or what would u suggest
tyrone09
#2 Posted : Friday, November 12, 2010 9:23:10 AM(UTC)
tyrone09
any suggestions
#3 Posted : Friday, November 12, 2010 9:30:32 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for MAYTAG PYE2200AYW Dryer - Ele | AppliancePartsPros.com
The thermostat (thermal fuse) (Item 5 in Section 4) is a common fault.
Also high on the list is the door switch and the push to start switch.
If the thermal fuse is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I believe richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
tyrone09
#4 Posted : Friday, November 12, 2010 9:49:13 AM(UTC)
tyrone09
Ok, thanks. I will let you know my results
