scox
#1 Posted : Wednesday, November 10, 2010 1:08:19 PM(UTC)
scox
Two of the burners are not heating on cooktop. The front left and the middle warmer burner. The light comes on on the panel when you turn the knob on but not heat to the burners. The other 3 burners are working just fine. This is a smooth glass cooktop. The oven portion of the range is working fine as well.
Is this an element problem or a fuse or something?
EricRoc
#2 Posted : Tuesday, November 23, 2010 3:49:02 PM(UTC)
EricRoc
I'm having a similar problem on a Jen Air electric range. The rear left burner is not heating up at all. The light above the dial lights up, but no heat whatsoever. Everything else is working fine. The model is Jen Air 8114p926-60. Hopefully someone will post their thoughts on why the burner isn't working and what we can do about it.
