Lately our oven has been coming on with the switch in the off position, it does not heat all the way, just warms up slightly. Working the switch off and on sometimes will shut it off, is this just a switch problem or something else? Thanks for any replies.
Originally Posted by: ram04 Lately our oven has been coming on with the switch in the off position, it does not heat all the way, just warms up slightly. Working the switch off and on sometimes will shut it off... Did you mean the oven thermostat? Gene.
Sorry, yes it is the thermostat. It seems to work fine, except for every now and then it comes on by itself on a warm setting. Is there some way to fix this or do I replace the thermostat?
The thermostat has to be replaced. - The part number for the oven thermostat is AP2023656 Gene.
Thanks, I'll do that this weekend.
