Ok so I am in a rental and the dishwasher has not worked properly for some time now and I have had the landlord out to fix it and it works for a time or two and then nothing. OK so here is the problem. I run the dishwasher on normal setting and the dishes come out sometimes with soap still on them and waterspots and sometimes some stuff still on them. Also at times the soap in the dispenser is gooed up so obviously its not working somewhere. We have hard water so it seems like some thing is plugged at least that is what i was told but I dont think that that is it. Does anyone have any suggestions.
Check if all holes in both spray arms are open. Check if there is a white stuff covered inner parts in the dishwasher. Post your findings.
