ApplianceRepairJJS
#1 Posted : Tuesday, November 9, 2010 12:56:56 PM(UTC)
ApplianceRepairJJS
Dishwasher started draining water intermittantly. Found a pretty consistent leak under the flood switch. Enough to get shocked when I touched the bracket. Could a shorting flood switch cause the draining to be inconsistent? Look like the switch assy is a simple repair but will it fix the problem?
magician59
#2 Posted : Tuesday, November 9, 2010 1:16:52 PM(UTC)
magician59
If you're referring to the float switch, its only function is to interrupt the power to the fill valve, if the water level rises to a predetermined level--which would cause it to leak or be splashed out the door. It is possible for a leak to migrate into other components, like the drain pump, if it is severe enough.
While you're servicing the float assembly, check the switch for proper operation: It is normally closed, when the float is down; and should open as the float is lifted away from it.
ApplianceRepairJJS
#3 Posted : Tuesday, November 9, 2010 1:33:17 PM(UTC)
ApplianceRepairJJS
what would cause intermittent draining. Sometimes drains all the way out, other times partial drainage. Does this switch not regulate that also?
magician59
#4 Posted : Tuesday, November 9, 2010 5:40:51 PM(UTC)
magician59
This switch does not control drain function. Check under the sink, where the drain hose goes to your drain (and garbage disposer, if you have one). If n the drain hose is clear and unkinked, make sure it loops as high as possible before going to the drain. It is also possible that the drain pump itself may be partially obstructed.
Run water into the dishwasher, and then select "Cancel/Drain". Listen to see if the pump motor continues to run throughout the drain cycle. If not, you may need to replace the pump.
