HomerH209
#1 Posted : Tuesday, November 9, 2010 10:50:59 AM(UTC)
HomerH209
The ice maker just stopped making ice. I checked the troubleshooting section of the owner’s manual and it was worthless because I already knew that it needed to be plugged in, switch turned to on, and the thermostat set to below freezing.
So now I am to the next step of asking the expert. Just to make sure that there was enough water in the ice maker I added some more using a cup and it is now full. However, the ice did not come out of the ice maker after 24hrs. The dispenser light sensor on the R/H side of the freezer is now red and blinks twice then pauses for a bit and then repeats with the flapper door covering the light path. With the flapper door out of the way the light is a constant red and goes out with the door closed.
#2 Posted : Tuesday, November 9, 2010 1:23:57 PM(UTC)
If the real temperature in the freezer is bellow 10°F, replace the ice maker.
- The ice maker Part number: AP4360427
HomerH209
#3 Posted : Wednesday, November 10, 2010 12:00:07 PM(UTC)
HomerH209
Gene,
Yes the temp inside the freezer is below 10°F.
Will the new ice maker come with installation instructions?
#4 Posted : Wednesday, November 10, 2010 5:15:31 PM(UTC)
The instructions are attached to the reply.
File Attachment(s):
HomerH209
#5 Posted : Tuesday, November 30, 2010 7:27:40 AM(UTC)
HomerH209
Your diagnosis was spot on. The part number you provided was exactly what I needed and the instructions were easy to follow.
Thanks for you help.:)
#6 Posted : Wednesday, December 1, 2010 12:58:45 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Ice maker stopped working... (Refrigerator & Freezer Repair)
by Steelwheels1 4/6/2015 3:51:42 AM(UTC)
GE Adora Fridge: Ice Maker stopped working. (Refrigerator & Freezer Repair)
by lighthouse832 1/7/2010 12:50:11 PM(UTC)
