I have a whirlpool built in oven not working with error code E3 F2. I think the problem is the oven temp sensor. If correct, how hard is this part to replace?
The error code you posted means there is something wrong with the control panel. The model number you posted is incorrect. Verify and repost it, please.
The correct model number is RBS305PDQ2....error code E3 F2.
thanks
Can you elaborate the appearance of this error code?
The E3 is red in color and just to the left of F3 which is yellow in color. That's all that appears on the control board. The control panel periodically beeps. Following the manufactures suggestion I tried pushing the "cancel" on the control panel to no avail.
In accordance with the Whirlpool troubleshooting guide, the correction is replacing of the control panel. In order to provide the right part number for the control panel I need the color of it. Here are the break down diagrams for the Whirlpool oven Model RBS305PDQ2Gene.
Thanks for your help, I have the part number however, considering the cost of the panel I will replace the oven. Thanks again
